Delete a PTP clock instance.
| boundary | Delete the boundary clock instance. |
| ordinary | Delete the ordinary clock instance. |
| end-to-end-transparent | Delete the End-to-End transparent clock instance. |
Use this command to delete a PTP boundary, ordinary, or end-to-end transparent clock instance. We recommend that you delete the ordinary or boundary clock instance before you delete the end-to-end transparent clock instance.
The following commands delete an ordinary clock, boundary clock and end-to-end transparent clock:
# delete network-clock ptp ordinary # delete network-clock ptp boundary # delete network-clock ptp end-to-end-transparent
This command was first available in ExtremeXOS 15.1.
This command with end-to-end-transparent is available on 5420, 5520, and 5720 platforms. This command with boundary is available on 7520-48Y and 7720 platforms.
